October 1, 2024 at 7:41 am
harunprakash.mech
SubscriberWhile importing odb++ file ,only copper layers and dielectric layers are getting imported,solder mask layer is missing. Can you suggest ways to import solder mask layer to pcb.
October 8, 2024 at 2:57 pm
Iceman
Ansys EmployeeWhat tool are you using? Classic Icepak or AEDT Icepak? Thanks. -
October 15, 2024 at 7:43 am
Aymen Mzoughi
Ansys EmployeeTry using either Ansys EDB or IPC2581 for import
October 15, 2024 at 3:00 pm
Iceman
Ansys EmployeeIf you are using Classic Icepak, the solder layer will be ignored. Please manually create the solder layer using a block object. In AEDT Icepak, solder layer can be imported into PCB component.
