February 14, 2022 at 3:06 pm
Nabuzor
SubscriberHello all,
I am facing a problem of obtaining good material data input for my simulations. I would like to work on calculating stresses and strains of elements made of forged brass. Unfortunately, no manufacturer provides mechanical data for forgings, only for brass bars in different delivery states. However, I have an access to data (force - elongation graphs) obtained in an experiment where the forging itself was subjected to tension.
Therefore I would like to ask if there is a way I could somehow replicate this test in simulation in order to retrieve an approximate stress - strain data for the material properties for future simulations? If yes, how should I proceed with material settings in such test replication?
I will be thankful for any answers.
All the best!
February 14, 2022 at 6:04 pmAshish Khemka
You can try converting the force-elongation data to stress-strain data and then define the relevant material model.
Regards Ashish Khemka
February 14, 2022 at 6:21 pmNabuzor
I am not sure how to do it excatly - as I wrote, I am dealing with forging and it has a non uniform shape with varying cross sectional area, far from being round. In such case I do not know how to convert force data into stresses - do you have any specific way of doing that on mind?
All the best!
February 17, 2022 at 2:18 pmFebruary 24, 2022 at 6:35 amjonsoln
SubscriberHello!
I don't think you will be able to create stress-strain data more than in the elastic range from a general force-displacement experiment with an irregular specimen. You could estimate the young's modulus though.
Viewing 4 reply threads- The topic ‘Obtaining stress – strain curve from experiment’ is closed to new replies.
Innovation SpaceTrending discussions- LPBF Simulation of dissimilar materials in ANSYS mechanical (Thermal Transient)
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
Top Contributors-
4167
1487
1358
1189
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
