November 30, 2023 at 11:40 am
N. M.
SubscriberHello Everyone.
I need to conduct a Fluent simulation of airflow around an aircraft engine cowling, both externally and internally.
However, I encounter an issue during the geometry creation phase. I import the engine cowling geometry from a .step file, and in Design Modeler, it appears as shell bodies (it is not an error, the original .step file contains surfaces). To create the fluid domain (representing the air passing around and into the coverage), I require a true 3D object of the engine cowling. This is essential for using the boolean (subtract) tool to subtract it from the ambient air volume.
To achieve this, I need to transform the initial shell bodies of the engine cowling into a 3D object (with walls having a thickness). How can I accomplish this?
Thank you ????. -
December 1, 2023 at 3:34 pm
Essence
Ansys EmployeeHello,
Can you please share the screenshots of the model? Did you try it out in SpaceClaim or Discovery?
- The topic ‘Obtain a 3D object (with volume) starting from shells’ is closed to new replies.
