May 19, 2024 at 11:09 pm
c76zhang
SubscriberHi,
I'd like to model the effect of a thin layer of oxide on my device capacitance and inductance. This is done by implementing a 10um*5nm strip of oxide on top of the metal (10um*145nm), with the region size at 630um*800um). Simulation throws an error "Couldn't find perimeter of closed object. Possible reason: some dimensions may be too small. Please try classic mesh!"
I previously had a discussion on using classic mesh. I now need to explicitly simulate this small model object with the given region size. Please give advice on what can be done to make the simulation run.
Chi Zhang
May 26, 2024 at 2:23 am
c76zhang
SubscriberHi,
Please follow up on this topic. Setting up non-model regions and equating the D field in the case where there would be oxide to calculate the participation ratio has significant limitations in result accuracy. In the 2D solver, I cannot modify the model resolution, nor can I switch to classic mesh. Taken at face value there seem to be a big limitation of the software for calculations related to thin layers.
Chi Zhang
June 5, 2024 at 3:41 pm
HDLI
Ansys EmployeeHello Chi,
   Is it possible for you to use 3D model with classic mesh? In 2D's initial mesh settings, we can enter a small tolerance for model resolution in advanced tab, but I do not think it can resolve the problem.Â
HDLI
June 5, 2024 at 3:55 pm
HDLI
   Is it possible for you to use 3D model with classic mesh? In 2D's initial mesh setting, we can enter a small tolerance for model resolution in advanced tab, but I do not think it can resolve the problem. Thanks.
HDLI
- The topic ‘Objects with small model dimensions in Ansys Maxwell’ is closed to new replies.
5754
