June 23, 2021 at 8:59 am
Dimitri Goethals
SubscriberHi,Â
When can we expect SpaceClaim to support NX 1961 files?
Current release only allows NX 1899 and older.
Dimitri
June 23, 2021 at 9:39 am
Charudatta Bandgar
SubscriberHello Dimitri G
Let me check with the team, I will get back to you.
Regards.
June 24, 2021 at 10:12 am
Charudatta Bandgar
The plugin will be supported at SpaceClaim 2021 R2 whereas the reader will have support at 2022 R1, the release timelines aren't certain yet, though tentatively the 2021R2 will be releasing sometime in next month, whereas 2022 R1 will be releasing in early 2022.Â
Regards.
June 24, 2021 at 10:18 am
Dimitri Goethals
SubscriberHi Charudatta Bandgar
What is the difference between a plugin and reader? And where do I find this plugin?
Regards.
July 15, 2021 at 2:42 pm
Dimitri Goethals
SubscriberHi Charudatta BandgarÂ
I installed 2021R2 and the nx file is still not loading into the software.
In your answer you spoke about a plugin => where can I find this plugin?
Dimitri
- The topic ‘NX 1961 file support’ is closed to new replies.
5694
1891
1419
