April 5, 2024 at 9:25 am
vera-lise.schmitt
SubscriberHello,
I need to use MAC calculator on 2 modal models which are nearly identical. When I import with MAC calculator the 2nd rst, the model is not on the same scale than the 1st one. The 2 models have the same units (mm, t, N, ...).
Did someone ever used successfully MAC calcultator ?
Thank you !
April 8, 2024 at 8:00 am
Ashish Khemka
Forum ModeratorHi,
Please search for an article titled as below, which may be useful:Â
Modal Assurance Criteria MAC with Ansys for select Measurement Locations
Ashish Khemka
April 8, 2024 at 11:46 am
vera-lise.schmitt
SubscriberHi,
Unfortunately, it doesn't help with the new NVH Toolkit. I know how to use MAC with APDL but I don't with NVH toolkit.
Regards
April 8, 2024 at 1:20 pm
Matt Mehalic
Ansys EmployeeHi VeraL,
I don't understand what you mean by "the model is not on the same scale", but yet you indicate they are of the same units. Can you please elaborate?
- The topic ‘NVH Toolkit and MAC Calcultator – problem with rst import’ is closed to new replies.
5934
1306
