December 7, 2024 at 10:28 am
Himanshu
SubscriberHello,
I am working on single slope solar still simulation. I have made geometry by design modeler. For meshing, I have used fluent with meshing. If i use unstructed and hexa mesh then i got floating point error after some iterations.
I am using following models:
- Multiphase VOF model: Implicit, 2-phase (Phase-1:- Air-vapor mixture and Phase-2:- Water-liquid), Lee model for evaporation and condensation.
- Species Transport: To make mixture phase only.
- Viscous model: Laminar
- Radiation model (Discrete Ordinates and Solar ray tracing): Solar calculator
Boundary conditions: Glass cover: Mixed (Thermal), Semi-transparent (Radiation)Â Â Â Bottom plate: Adiabatic (Thermal), opeque-yes (Radiation)Â Â Other walls and collector: Adiabatic (Thermal), Opeque-No (Radiation).
Solution methods: SIMPLE Scheme
Total time of simulation is 11 hours (50400 sec).
Issues:
- From the close domain, mass of water is getting zero while vapor is not generated during simuation.
                              at t = 0 sec                                                           at t = 3215 sec
i have tried with 3 phase also (air, vapor and water) by keeping all parameters same, still i got same issues.
December 9, 2024 at 11:16 am
Forum ModeratorIf the domain is sealed what gas phase density option are you using? If you focus on the first second or so what's going on in the model?
December 9, 2024 at 12:51 pm
December 9, 2024 at 1:16 pm
Forum ModeratorIf liquid evaporates into vapour where does it go?Â
December 9, 2024 at 1:24 pm
Himanshu
SubscriberFirst thing, water vapor is not generated during the simulation and water-liquid volume fraction was reduing with flow time. Water-liquid volume fraction is having range 0-1 before the simulation and 0-9.92e-5 after 3451 sec (Flow time) and after that 0-0.
where the water is going from the close domain, i don't konw.
December 9, 2024 at 1:32 pm
Forum ModeratorAnd does the temperature increase during the simulation? Look at the vapour density option and tell me where the expaned vapour goes.Â
December 9, 2024 at 2:02 pm
December 9, 2024 at 2:15 pm
Forum ModeratorYou have a fixed volume. You have expansion of the vapour phase as temperature rises. Where does the excess volume go?Â
December 10, 2024 at 8:50 am
Himanshu
SubscriberI already mentioned vapor was not generated during the simulation.
December 13, 2024 at 10:44 am
Himanshu
SubscriberSir, can you help me in this project?
December 13, 2024 at 11:27 am
Forum ModeratorBut vapour does expand?Â
December 13, 2024 at 11:46 am
Himanshu
SubscriberHow can i ensure, whether vapor is expending or not?
Can you tell me something to verify it?
December 13, 2024 at 12:09 pm
Forum ModeratorYou're using incompressible ideal gas so it's got to expand if the domain is warming up. Given that, where does the excess volume go?Â
December 13, 2024 at 1:29 pm
Himanshu
SubscriberTemperature of water is increasing during the dimulation but vapor is not generated. I used 2-phase due to mixture of air and water vapor, so generated vapor will be prasent with air.
December 13, 2024 at 3:59 pm
Forum ModeratorYes, which means the gas is expanding. So, where is the gas going?Â
December 14, 2024 at 10:16 am
Himanshu
Subscribergas is inside the close domain only. In the domain, neither inlet nor outlet is provided.
December 16, 2024 at 9:58 am
Forum ModeratorYes, and if the gas expands as it gets warm in a sealed domain where does the excess go?Â
December 16, 2024 at 10:57 am
Himanshu
SubscriberGas in the domain is not expanding.
December 16, 2024 at 11:24 am
Forum ModeratorWhat is the gas density model?Â
5849
