May 19, 2023 at 9:01 pm
Taher hafiz
SubscriberAnsys is a powerful tool, but I want to thoroughly understand Ansys software by answering the following technical and engineering questions.
- How could Ansys aid in understanding the underlying mechanism of heat transfer through metallic and non-metallic?
- Can Ansys be utilized in the computational modeling of thermal insulation on the steel surface to estimate the protective film's heat conduction/convection behaviors?
- How does Ansys modeling help simulate and calculate the heat (convection, conduction, radiation) starting from a heat source to the protective layer and from the protective layer to the metal substrate?
Are there any documents that explain the details of Computational Simulation?
Thanks for the details.
May 19, 2023 at 10:15 pm
peteroznewman
SubscriberI posed these questions to ChatGPT, the OpenAI program that makes up answers. Sometimes the answers are true and other times the answers are not true. Let’s see how it answered:
Ansys can aid in understanding the underlying mechanism of heat transfer through metallic and non-metallic materials through its multiphysics simulation capabilities. With Ansys, you can simulate heat transfer phenomena using various methods such as conduction, convection, and radiation. By setting up appropriate material properties, boundary conditions, and solving the governing equations, Ansys can provide insights into how heat propagates through different materials. This can help in understanding temperature distributions, thermal gradients, and heat fluxes within the materials, thereby enabling a better understanding of the heat transfer mechanisms.ÂYes, Ansys can be utilized in the computational modeling of thermal insulation on a steel surface to estimate the protective film’s heat conduction and convection behaviors. With Ansys, you can create a 3D model of the steel surface, apply the appropriate boundary conditions (e.g., temperature, heat flux), and define the properties of the thermal insulation material. By solving the heat transfer equations, Ansys can calculate the temperature distribution within the insulation layer and provide insights into its heat conduction and convection behaviors. This can help in evaluating the effectiveness of the insulation in reducing heat transfer and estimating its thermal performance.ÂAnsys modeling helps simulate and calculate heat transfer (convection, conduction, radiation) starting from a heat source to the protective layer and from the protective layer to the metal substrate through its multiphysics capabilities. You can define the heat source, material properties, and boundary conditions within Ansys to accurately represent the system. Ansys uses numerical methods to solve the governing equations for heat transfer, including convection, conduction, and radiation. By simulating these phenomena, Ansys can provide detailed information on temperature profiles, heat fluxes, and heat transfer rates at different locations within the system. This allows for a comprehensive understanding of the heat transfer processes involved.ÂAnsys provides extensive documentation and resources to explain the details of computational simulation. The official Ansys documentation includes user guides, tutorials, and technical papers that cover various aspects of simulation using Ansys software. These resources offer detailed explanations of different features, workflows, and techniques for performing simulations in Ansys. Additionally, Ansys also provides online forums and community platforms where users can ask questions, share knowledge, and access further support. Access to these resources can greatly aid in understanding the computational simulation capabilities of Ansys. -
June 21, 2023 at 1:10 pm
Taher hafiz
SubscriberWhat are the type of mesh size and advantages of mesh sizeÂ
- The topic ‘Numerical Simulation and Mathematical modelling for academic research’ is closed to new replies.
 - APDL, memory, solid
 - Meaning of the error
 - Contact stiffness too big
                        1487
                        1363
                        1194
