March 25, 2024 at 11:42 am
Stemphanie_anansu
How do you evaluate the quality of the particles emitted by the DPM?
I emitted 30,000 particles and half of them emitted incomplete, is this considered a success? If it is not successful, how should I improve it?
I have a residual of 1e-6 for the continuum equation of the flow field before launch, and 1e-8 to 1e-10 for the rest.thanks
March 25, 2024 at 12:27 pm
Forum ModeratorAs an aside you're tracking parcels and not particles - it's a terminology issue from when the model was first introduced.Â
With 50% incomplete you have a lot of mass stuck somewhere in the domain. That may be a "success" for a separator, but also suggests some more care should be taken with boundary conditions. Using the Particle Tracks panel skip some (with 30k in the system 300 isn't a bad idea) and see where they're going. Increasing the particle max steps may be a good idea, but use some care otherwise you may be waiting a long time for a DPM update.Â
March 25, 2024 at 1:20 pm
March 25, 2024 at 2:09 pm
Forum ModeratorYou can't set incomplete as a success/failure criterion without understanding what is happening in the flow. In a filter system with a poor choice of DPM boundary conditions incomplete could imply particles are stuck somewhere, so it's a success in that I've got 50% separation, or it could be a failure as I've only got 50% separation. In a combustor it means a portion of the fuel is floating around and we don't know why it's not burning or leaving the domain.Â
- The topic ‘Number of particles emitted by DPM’ is closed to new replies.
