March 7, 2018 at 11:36 pm
Drohianik10
SubscriberWhat is the meaning of the number of parallel paths in transient solver of Ansys Maxwell?
June 13, 2018 at 2:05 am
Mark Solveson
Ansys EmployeeWhen connecting windings in an electric machine, for example, multiple sets of coils may be connected in series or in parallel. Â
If you have 4 coils, setting the parallel paths to 2 in a Winding definition, would connect 2 parallel connections of 2 series coils.  -
June 14, 2018 at 3:52 pm
Drohianik10
SubscriberThank you for your answer.
- The topic ‘Number of parallel paths in Ansys Maxwell’ is closed to new replies.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1241
1118
1015
