Number of faces given by the GUI and obtained using UDF are different (Fluent)
    • KeFon
      Good morning,
      I am trying to export data to compute a local property.
      I want to retrieve data on faces that are on two opposite sides of a same wall.
      Because of the mesh construction, I expected the number of faces on both threads to be the same which I could confirm using the GUI:
      Zone sizes on domain 1:
      1089 quadrilateral wall faces, zone 4.
      1089 quadrilateral wall faces, zone 7.
      1089 quadrilateral wall faces, zone 5.
      1089 quadrilateral wall faces, zone 18.
      84124 nodes.
      I am interested in faces in zone 4 and 5.
      Using a UDF to write on two files the data from these two zones, I get a different number of data for each zone.
      Here is a portion of the UDF to show how I defined the domain and threads and how I computed the number of elements :
      DEFINE_EXECUTE_AT_END(export)
      #if !RP_HOST
      Domain *mix_domain=Get_Domain(1);
      Thread *wall_thread_NH3=Lookup_Thread(mix_domain,5);
      Thread *wall_thread_water=Lookup_Thread(mix_domain,4);
      #endif
      #if RP_NODE
      size_water = THREAD_N_ELEMENTS_INT(wall_thread_water);
      size_NH3 = THREAD_N_ELEMENTS_INT(wall_thread_NH3);
      #endif
      Which gives a total of 1725 faces for zone 5 and 1623 faces for zone 4.
      Could someone explain where the differences are coming from?
      Thank you.
      If you try the UDF in serial what do you get?
    • KeFon
      Thank you very much for your fast answer. We had an issue with the license server and I could not try it until today.
      Using Fluent in serial mode, I get the same number of faces from the macro THREAD_N_ELEMENTS_INT and from the GUI for both sides (1089).
      Seeing this result, I tried to include a loop on the faces to count them in parallel mode using if (PRINCIPAL_FACE_P(f,*corresponding thread*)) first. The sum of the counted cells gave 1089 for both sides.
      I could use a first loop to get the number of faces and then a second one to get the properties but I would rather avoid that solution if possible.
      Thank you.
  • The topic ‘Number of faces given by the GUI and obtained using UDF are different (Fluent)’ is closed to new replies.
