April 26, 2021 at 5:19 pm
ssaeidab
SubscriberHi,nour Lab in the university has a Maxwell Ansysy's student license and academic research license. I was wondering with this license how many cores of CPU we can use for simulation?nThanksn -
April 28, 2021 at 6:26 pm
VivekKamble
Ansys EmployeeHello Array,
If you are running 2021 R1, you can use 4 cores.
Vivek
April 28, 2021 at 6:37 pm
ssaeidab
SubscriberHello Array ,
Thank you for your replying.
Even if we have an Academic research license? I saw if we have an academic research license we can use 16 cores of CPU. I am doing the simulation of the electrical motor in 3D and it takes so long. I saw here we can use 16 cores of CPU to decrease the simulation time. Also, we want to get a new computer with powerful CPU that has a multicore to accelerate the simulation. Based on your answer we can not use more than 4 cores of CPU for simulation, even if we have an academic research license, am I right?
Also, do you have any suggestions to increase the speed of simulation?
Thank you for your help and consideration.
Saeid
August 24, 2022 at 1:36 pm
Praneeth
Ansys EmployeeHi Saeid,
Thank you for reaching to us and we regret that this post was not answered for a long time. I am providing the required details so that other users who are searching for this can get benefited.
My colleague said that you can use upto 4 cores for student version of AEDT. Regarding academic research license, you are right. You can use 16 cores for accelerating the simulation.
Best regards,
Praneeth.
- The topic ‘Number of CPU cores for parallel Processing’ is closed to new replies.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
1461
1287
1135
