NTGK Low heat generation problem
    • 1929974
      Hi all,
      I'm simulating a 1S3P cylindrical 21700 battery module using the MSMD-NTGK model in Fluent 2024 R2, and I’ve encountered a puzzling result regarding heat generation.
      What I did:
      1. Using SpaceClaim, I created a single 21700 cell with positive and negative tabs.
      2. I copied that cell-tab set to build a 1S3P configuration (three parallel cells in one series).
      3. Then I created busbars to connect the tabs accordingly.
      4. In Fluent, I assigned the NTGK battery model properly, defined the pack as 1S3P, and applied a 3C-rate discharging condition.
      5. Each cell is defined as an individual solid zone (cell_1_1s1p, cell_2_1s2p, etc.), and I confirmed that the total current is correctly distributed (14.4 A total, 4.8 Ah × 3 × 3C).
      The issue:
      - In my previous single-cell 1.5C simulation, the volume average heat generation rate was about 60,000 W/m³.
      - But in this 1S3P module 3C simulation, the volume average heat generation rate was about 60,000 W/m³.
      - This seems too low, and no increase in heat generation is observed despite increasing the overall current and cell count.
      What I already checked:
      - The 1S3P connection is correct (battery pack: 1S3P confirmed in console).
      - All cells are separate solid zones (not merged).
      What I want to understand:
      Why is the heat generation lower than that of a single-cell 1.5C discharge, even though both the number of cells and the discharge C-rate have increased?
      I would appreciate it if you could point out where I might be making a mistake.
      Thanks in advance for any insight or advice!
      Battery Network Zone Information:
      Battery 1s1p
      Active zone: cell_1_1s1p
      Battery 1s2p
      Active zone: cell_2_1s2p
      Battery 1s3p
      Active zone: cell_3_1s3p
      Passive zone 0:
      bar2
      n_tapzone_1
      n_tapzone_2
      n_tapzone_3
      Passive zone 1:
      p_tapzone_1
      p_tapzone_2
      p_tapzone_3
      bar1
      Number of battery series stages = 1; Number of batteries in parallel per series stage = 3
      *************END OF BATTERY CONNECTION INFO***********
Viewing 0 reply threads
