July 13, 2024 at 4:58 pm
July 20, 2024 at 5:19 pm
javat33489
SubscriberI tried to increase the coefficient of friction to 0.6 (steel-concrete), but the temperature rose to only 305K.
Help Please.
July 23, 2024 at 11:12 am
Ashish Khemka
Forum ModeratorHi,
Please check if the problem#4 is of use to you: Microsoft Word - thermal.doc (dynaexamples.com)
Ashish Khemka
July 29, 2024 at 4:43 pm
javat33489
SubscriberSir, this file won't help me. There are no answers to such questions.
I did a thermal analysis where I drilled a die from SPG and SPH but the result is the same, the teeth on the drill that I'm examining do not heat up more than 1K.
The initial temperature is set to 295K, as a result of a small drilling I see the teeth heating up to 295.2K.
When drilling an SPG die, neither the teeth nor the die itself heat up. When drilling an SPH, the teeth do not heat up, but the SPH die heats up like crazy.
Friction coefficients = 0.5.SPG:
SPH:
Analysis settings again:
During the calculation I also receive such warnings. Could this be related?
P/S. For SPH, I considered the same model as SPG, I only replaced SECTION with SPH.
- The topic ‘Nozzles on the drill do not heat up’ is closed to new replies.
6104
