Notch Effect
    • Jeonee
      Notch effect is significant for fatigue. Every component cannot produce very well. Sometime controlles can miss the notch on the component. I want to do notch effect static analysis in Ansys then I will do fatigue analysis in nCode. However, I have a problem. As you know, when I add notch on the component, there will be singularity stress on the component. I want to prevenet this situtation. What can I do? Can you help me, please?
    • ErKo
      Hi
      Perhaps this helps.
      https://www.linkedin.com/pulse/stress-singularities-concentrations-mesh-fea-marcos-ac%C3%ADn-gonz%C3%A1lez
      All the best
      Erik
      • Jeonee
        Thank you so much
  • The topic ‘Notch Effect’ is closed to new replies.
