November 6, 2024 at 9:16 am
jascorbe
SubscriberHi,Â
I have this geometry in SpaceClaim: it is a screw+washer assembly with shared topology configuration. Clearly, there are no face imprint while in SpaceClaim:
But after exporting this to mechanical, I get the shared faces imprinted, that makes sweep operation not possible:
Does anybody know how to fix this problem?
Thank you.
Best regards
November 6, 2024 at 11:01 am
ErKo
Ansys EmployeeÂ
Hi
Imprints are generated via the shared topology – normally with these bolts you (very simple) show, we can sweep – try using multizone (leave default set.) on all the bolts as that should also do it.
All the bestÂ
Erik
November 25, 2024 at 3:30 pm
jascorbe
SubscriberThank you Erik
1306
