September 28, 2023 at 2:24 pm
Lachlan Wensley
SubscriberHi there,
I am currently trying to do a magnetostatic simulation on a magnetorheological fluid brake for my thesis. I am trying to simulate total and directional magnetic flux density. I am getting an error saying Insufficient HPC Licenses available. Below is the full solution information. Also on another note if any one has any good tutorials regarding MR fluids and simulating the stress from the fluid flow and temperature etc that would be awesome.
Ansys Mechanical Enterprise Academic Student    Â
 ANSYS LICENSE MANAGER ERROR:
 Not enough HPC Parallel licenses 4/2.
 *** ERROR - Insufficient HPC licenses available.
whybad=Â Â Â Â Â Â -1074
+--------------------- M A P D LÂ Â S T A T I S T I C S ------------------------+
Release: 2023 R2Â Â Â Â Â Â Â Â Â Â Â Build: 23.2Â Â Â Â Â Â Update: UP20230531Â Â Platform: WINDOWS x64
Date Run: 09/29/2023Â Â Time: 00:09Â Â Â Â Process ID: 6528
Operating System: Windows 10Â (Build: 19045)
Processor Model: AMD Ryzen 5 3600 6-Core Processor
Compiler: Intel(R) Fortran Compiler Version 19.0.5Â (Build: 20190815)
         Intel(R) C/C++ Compiler Version 19.0.5 (Build: 20190815)
         Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191125
         BLAS Library supplied by AMD BLIS
Number of machines requested           :   1
Total number of cores available        :  12
Number of physical cores available     :   6
Number of processes requested          :   1
Number of threads per process requested :Â Â Â 4
Total number of cores requested        :   4 (Shared Memory Parallel)                  Â
GPU Acceleration: Not Requested
Job Name: file
Working Directory:
Total CPU time for main thread                   :       0.2 seconds
Total CPU time summed for all threads            :       0.1 seconds
Elapsed time spent obtaining a license           :       0.4 seconds
Elapsed time spent pre-processing model (/PREP7)Â :Â Â Â Â Â Â Â 0.0 seconds
Elapsed time spent solution - preprocessing      :       0.0 seconds
Elapsed time spent computing solution            :       0.0 seconds
Elapsed time spent solution - postprocessing     :       0.0 seconds
Elapsed time spent post-processing model (/POST1) :Â Â Â Â Â Â Â 0.0 seconds
Sum of disk space used on all processes           :       0.0 MB
Sum of memory used on all processes              :       2.0 MB
Sum of memory allocated on all processes         :       0.0 MB
Physical memory available                        :        16 GB
Total amount of I/O written to disk              :       0.0 GB
Total amount of I/O read from disk               :       0.0 GB
+------------------ E N DÂ Â M A P D LÂ Â S T A T I S T I C S -------------------+
 |                              RUN COMPLETED                                |
 | Ansys MAPDL 2023 R2        Build 23.2        UP20230531   WINDOWS x64  |
 | Database Requested(-db) 1024 MB    Scratch Memory Requested        0 MB |
 | Maximum Database Used      1 MB    Maximum Scratch Memory Used     1 MB |
 |       CP Time     (sec) =         0.062      Time = 00:09:27         |
 |       Elapsed Time (sec) =         1.000      Date = 09/29/2023       |
 *-----------------------------------------------------------------------------*All
September 29, 2023 at 1:24 pm
Forum ModeratorAs a guess, if you asked for 4 parallel but only 2 are available I'd try re-running with 2 parallel processes. The licence limits how many cpu can be used.Â
- The topic ‘Not Enough HPC Parallel Licenses 4/2’ is closed to new replies.
3862
1414
1241
1118
1015
