November 3, 2023 at 5:46 am
cb.en.u4ece20101
Subscriber " Port refinement, process hf3d error: Port 1 does not have a solved inside material on either side.. Please contact Ansys technical support. "
November 3, 2023 at 6:11 pm
Faezeh Tork Ladani
Ansys EmployeeHi Abinav,Â
Have you set the proper boundary assignment? For example, a Rad boundary around everything where the waveports are sitting right on the boundary.... This assignment also helps to create the vacuum or air material inside the solve region.Â
- The topic ‘Not able to simulate my model.’ is closed to new replies.
