July 25, 2021 at 2:24 pm
Amith_Anoop_Kumar
SubscriberJuly 25, 2021 at 2:54 pmpeteroznewman
SubscriberFracture Tool does not work on shell elements.
July 25, 2021 at 4:11 pmAmith_Anoop_Kumar
SubscriberThanks for the reply . But the problem is ansys 2D , so is there a method we can give solid elements to a 2D surface . Because this is a problem taken for verification manual of ansys hence there a surface itsel is used itsnt a 3d component so how to proceed
July 25, 2021 at 6:15 pmpeteroznewman
SubscriberMy understanding is a pre-meshed crack requires 3D solid elements. If there is an ANSYS verification model that shows a 2D model, I don't know about it.
If you want to proceed with a Pre-Meshed Crack, I suggest you create the crack faces in a 3D solid body using SpaceClaim, but you need good geometry creation skills.
I recommend you use a Semi-Elliptical Crack, which requires no geometry preparation.
Viewing 3 reply threads- The topic ‘Not able to proceed with pre meshed crack’ is closed to new replies.
5834
