normal stress issue of random vibration
    • zengmin
      Hello guys. I built a space frame structure model with beam 188 element and run random vibration analysis on it. But the normal stress distribution seems to be wrong. Can u help me find the possible reason ?
      I choose 9 bottom point as fixed support and apply displacement psd on Zdirection.
    • dlooman
      Beam postprocessing, especially after a psd analysis, can be difficult.  As a sanity check, could you try displaying the axial stress with the user defined result below?:
    • zengmin
      Thanks for your reply. The result is below:
    • zengmin
      I also added distributed mass and made prestress for modal analysis.But it doesnt effect the normal stress distribution. Here is all my keyopt. They are all default.
    • zengmin
      My beam sections are several kinds of I section with different parameters and tubular section with different parameters.
    • zengmin
      I form a part with all line body in designmodeler and chose edge joints as shared topology method
    • dlooman
      Prestress doesn't always change beam results.  There is a nicer capability for displaying beam results on the cross-section in APDL:
      /post1
      set,last
      /graph,power
      /esha,1
      /show,png
      plnsol,s,x        ! beam axial stress will be displayed over a 3D image of the beam
Viewing 6 reply threads
