February 10, 2024 at 6:59 pm
February 10, 2024 at 7:00 pm
February 10, 2024 at 7:01 pm
February 10, 2024 at 7:02 pm
peteroznewman
SubscriberThere are no errors. You are showing a warning that can be ignored. To remove the warning, upgrade your computer with more RAM and replace the HDD with a SSD.
February 10, 2024 at 7:05 pm
Noura Mansour
Subscriberwhat about force convergence plot
February 10, 2024 at 9:22 pm
peteroznewman
SubscriberConvergence plot looks very good. You have a fully converged solution.
February 11, 2024 at 12:00 am
February 11, 2024 at 1:27 pm
peteroznewman
SubscriberRead this discussion and come back if you have more questions.
February 11, 2024 at 8:31 pm
Noura Mansour
Subscriber.
February 11, 2024 at 8:35 pm
February 11, 2024 at 10:15 pm
peteroznewman
SubscriberBecause the self contact is Far Open, the contact is ignored and you are not getting the result you want. Change the Pinball Radius so that the Initial Contact is Near Open and solve.
February 11, 2024 at 10:28 pm
Noura Mansour
SubscriberApproximately how much do I take the value of pinball Radius?
February 12, 2024 at 12:52 am
peteroznewman
SubscriberAny number that changes the status from Far to Near.
Please Edit your previous post and delete the hundreds of lines of solution output. I am tired of scrolling past that. No one needs to read anything there.
February 12, 2024 at 9:43 pm
Noura Mansour
Subscribersorry for this i deleted it ..
i tried to make the radius to be 2 mm but the error of contact still occurs ,, i tried another method by changing the normal stiffness to 0,2 and detection method to nodal normal to tangent and the error of contact doesn't appear .Â
but i want to ask another question about this warning and info and the HDST element under solution information
February 13, 2024 at 1:26 am
peteroznewman
SubscriberWhat type of material is this spring made from? What material model is used in Engineering Data to represent that material?
One change that can help highly distorted elements is to set the minimum number of substeps to a large number. This may require that the initial number of substeps is also a large number. The maximum number of substeps should be 10 times larger.
- The topic ‘nonlinear spring simulation’ is closed to new replies.
- Add-in Error Excel
- Inconsistent Script
- MISSING SIMULATION SECTION/RIBBONTAP
- Unable to attach to geometry file 2025R2
- How would I select specific components and all bodies under it?
- Mesh tool questions SpaceClaim
4643
1540
1386
1225
