TAGGED: apdl, coupled-field, hyperelastic-material, nonlinear-material
May 2, 2024 at 9:38 am
Tino Damian
SubscriberHello everyone!
As the title says I am doing a structural-diffusion-coupling analysis in APDL with either Solid226 or 227. for the diffusion part I provide the diffusion coefficient and the migration table. When it comes to the structural material model I want to use a form of hyperelasticity, ideally Neo-Hooke, but the issue thta arises is best summed up by the following error message by the solver when trying to solve the model: More than one material option has been defined for material 1. Hyperelastic material (TB,HYPER) is not supported with other nonlinear material models.
Nothing in the availabe guides states that hyperelasticity is incompatible with the migration model, quite the opposite actually!
Am I misunderstanding the guides? Can someone please help me out with this?
May 2, 2024 at 5:15 pm
John Doyle
Ansys EmployeeSection 7.1, of the MAPDL Material Reference Guide, lists all supported material model combinations. Â HYPER + MIGR is not listed as a supported combination.
While SOLID226 does support HYPER materials in some coupled physics combinations, like Thermal-Structural (for example), the HYPER does not appear to be supported for Structural-Diffusion.Â
The SOLID226 Elements docs could be clearer on this point.
May 15, 2024 at 2:55 pm
John Doyle
Ansys EmployeeThe block is removed for the R2024-R2 release.
- The topic ‘Nonlinear material models for a structural-diffusion-coupling in APDL’ is closed to new replies.
5029
1724
1387
1248
