October 25, 2023 at 6:18 am
SULUN SHI
SubscriberHi,
I am doing a nonlinear analysis for the pretensioned concrete beam. The key focus is transfer length. After analyzing the beam, I checked several results. However, some parts were confirmed that were different from the predicted data.
My teacher suggested I achieve a tighter convergence in the analysis.
In addition to increasing the maximum number of iterations, I can use the CNVTOL command to set the convergence value for the nonlinear analysis. I have some questions:
- Convergence based issue: As far as the structure is concerned, which method has more convergence and better accuracy of the overall strain curve? Force or displacement?
- Is a lower tolerance value better?
- Minimum reference value. I don't understand what it is, Does this represent the best value of convergence achievable?Â
- What is the difference between VALUE and minimum reference value?
- Should the convergence value be as low as possible (e.g. 10^(-10)) or as high as possible (e.g. (1,000,000,000)) in order to achieve higher accuracy of the results?
October 25, 2023 at 6:50 am
ErKo
Ansys EmployeeDuplicate - use this post:
/forum/forums/topic/nonlinear-convergence-criteria-in-ansys-apdl/
- The topic ‘Nonlinear convergence criteria in ANSYS APDL’ is closed to new replies.
1565
1386
1242
