March 5, 2024 at 7:50 am
Alex Li
SubscriberHello Everyone,
When I run a nonlinear calculation, the process file has a warning, as follow:
‘A reference moment value times the tolerance is used by theÂ
Newton-Raphson method for checking convergence. The calculatedÂ
reference MOMENT CONVERGENCE VALUE = 1.938411291E-@3 is less than aÂ
‘threshold. This threshold defaults to 1.0-2 or is specified as MINREFÂ
‘on the CNVTOL command. Check results carefully.ÂMy assembly model has a lot of frictional contacts. This warning is whether or not the cause of contacts ? Â
Also the warning let me to check results caerfully, and how to determine ? Â
Thank you!
March 5, 2024 at 1:06 pm
Akshay Maniyar
Ansys EmployeeHi Alex Li,
Please check the below post with a similar warning message and its meaning.
Question about the meaning of a warning (ansys.com)
Thanks,
Akshay Maniyar
March 6, 2024 at 1:26 am
Alex Li
SubscriberThank you very much! I have got it.
March 6, 2024 at 7:09 am
Akshay Maniyar
Great. As your issue is resolved, I will close the thread.Â
Thanks,
Akshay Maniyar
- The topic ‘Nonlinear calculation questions!!!’ is closed to new replies.
