Nonlinear adaptive region error
    • jonsoln
      Hi!
      I'm running a static structural simulation with non-linear contacts, geometry and materials, and I want to try nonlinear adaptive region to see if that improves my convergence. However, the adaptive region is shown as deactivated for every step. I have turned on large deflections, I'm storing results at all time points, all contacts for the body are set to asymmetric augmented lagrange and the body is meshed with tet-elements, which should satisfy the limitations for the method. Still, there is a question mark next to the adaptive region in the tree and I get an error when trying to solve.
    • Rahul Kumbhar
      Did you try activate by right click on row in Tabular Data>>Activate/Deactivate?n
    • jonsoln
      Thanks! Most of the available Ansys settings have drop down menus, so I never though of right clicking!n
  • The topic ‘Nonlinear adaptive region error’ is closed to new replies.
