June 8, 2020 at 9:17 am
lei2019
I want to eliminate downstream combustion, because there is no fire there. I try to find some UDF code about this, but no code to do this work. I didn't find any option in fluent to stop the reaction in down stream zone. I have attached the temp result figure. I use Nonpremixed model, chemical equilibrium, non-adiabatic. 100% CH4 and 21% O2. Wall is constant temperature. 2D asymmetry model.Â
How to deal with it?Â
Thanks in advance.
June 8, 2020 at 9:18 am
June 8, 2020 at 8:32 pm
RK
Ansys EmployeeHello,Â
Just to be sure that i understood your question, you want cold flow (exhaust flow) in the downstream right?Â
June 9, 2020 at 1:53 am
lei2019
SubscriberYes, Rahkumar, the downstream shouldn't have combustion. It seems the combustion is governed by the PDF file; if there is proper ratio of methane and air, there will be combustion. Based on experiment, there should be no flame downstream.
(I use pressure outlet and P1 radiation model. The flammability limit is 0.1042.)
July 3, 2023 at 6:03 pm
Mathieu G
SubscriberHi !
I have the same issue. Did you find a way to prevent reactions in a specific zone ?
Thanks
- The topic ‘non premixed model of combustion under wire mesh’ is closed to new replies.
6189
