July 19, 2023 at 2:09 am
Proshat Mehdizad
SubscriberI am trying to solve an unsteady flow throuth porous media which is a SS mesh under non-equilibrium condition.Do I need to define an additional UDS to solve the porous solid surface temperature and susequently redifine the source term for fluid energy equation? Or when I check the non-qulibriem checkbox under the porous tab, fluent automatically solves the porous solid temperature and adjust the heat transfer between fluid and solid as a source term in fluid energy equation?
July 19, 2023 at 8:03 am
Forum ModeratorNon-equilibrium porous media should do what you need - check the documentation and if in doubt build a 2d test model. I assume the casing around the porous zone is well insulated?Â
July 19, 2023 at 12:00 pm
Proshat Mehdizad
SubscriberOk thanks. The reason for my question is that in some other CFD forums there were threads regarding adding a UDS for solving the solid temperature in porous zone, but those threads go back to couple years ago and I am not sue if Fluent had the non-equilibbrium solution at that point. So all in all, no additional UDS definition is required for solving the solid temperature in current version of fluent, correct?
July 19, 2023 at 12:25 pm
Forum ModeratorCorrect, the model's been in the code for a while but I can't remember which release. Current release is 2023R1 soon to be 2023R2.Â
- The topic ‘Non equilibrium porous media simulation fluent’ is closed to new replies.
5799
