August 13, 2019 at 8:47 pm
Bryan Drummond
SubscriberIs it possible to get coordinate information of individual nodes or of points added to the geometry in AIM?Â
I would like to look at the X-Y-Z coordinates of two points as well as the deflection at the same two points at the same time. I can add a point and get the deflection for that point, but I can't figure out how to get the coordinates of the point.
Ideally this would be something that I could create in SpaceClaim and the query in AIM
Suggestions?
August 14, 2019 at 1:55 pm
Naresh Patre
Ansys EmployeeHello Bryan Drummond
Let me check it and get back to you.
August 16, 2019 at 11:54 am
Naresh Patre
Though there is no direct way to get the X-Y-Z coordinates of points as well as the deflection at the same time, you can first calculate the X-Y-Z coordinates of points in SpaceClaim. If you select any point, you can see its coordinates at the bottom. Refer below image.
Now, for the same point, calculate displacement result (in Results task of AIM)
in X, Y and Z direction. If you add these displacements values to the coordinate data obtained from Spaceclaim, you will get the XYZ coordinate value of the point at the deformed location.
August 16, 2019 at 7:21 pm
Bryan Drummond
SubscriberNaresh PatreÂ
Can I create a point in SpaceClaim and carry it directly over into AIM? I tried that and wasn't successful, but there are at least two ways to create points and I may not have followed the correct procedure.
August 19, 2019 at 9:49 am
November 26, 2023 at 6:42 am
MuhammadAhsanZeeshan
SubscriberHello Everyone,
I made surface along my local coordinate at my 3d model in ANSYS workbench 2022 R1. I want to export normal stress data in my local coordinate. when i export normal stress data, it will obtain along global coordinate. But I want normal stress exported data in local x, y and z coordinates not along global coordinate.
- The topic ‘Node / Point Coordinate Information X Y Z’ is closed to new replies.
4904
1598
1386
1242
