November 16, 2022 at 7:02 am
mert.dedebeyoglu
SubscriberHello,
I am getting the following error in Static Structural analysis. When i search for the node "541889", nothing appears. The node does not exist.
Do you have any suggestions?
"The value of UX at node 541889 is 2.692029639E+14. Â It is greater than Â
 the current limit of 1000000 (which can be reset on the NCNV command). Â
 This generally indicates rigid body motion as a result of an      Â
 unconstrained model.  Verify that your model is properly constrained.  " -
November 16, 2022 at 7:46 am
Erik Kostson
Ansys EmployeeIt could be a node that is generated say for a remote point etc and that is not part of the mesh (generate mesh inside mech.). Get the model into apdl and see where that is or search the ds.dat file and find where it is being used.
November 16, 2022 at 8:45 am
mert.dedebeyoglu
SubscriberI checked the ds.dat file, and from the node I detected a missing contact.Â
Thanks for the help.
November 29, 2023 at 2:57 am
Brian Allen
SubscriberI also had the same error, thanks for posting, thanks to that I solved angel numbers
- The topic ‘Node number in the Solution Information does not exist’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
4207
1493
1375
1197
