August 17, 2023 at 3:07 pm
jetnis.avdijaj
SubscriberHi everyone, When I want to initialize a .cas setup, the fluent console give me this message:
Node 37: Process 9984: Received signal SIGSEGV.
= Â BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= Â RANK 39 PID 8376 RUNNING AT DESKTOP-XXXXXX
= Â EXIT STATUS: -1 (ffffffff)
 The fl process could not be started. -
August 18, 2023 at 12:13 pm
supreetha.j
Forum ModeratorHello,
Could you please provide more information on what you are modeling? When does this error come up and does it show any text above this?
August 18, 2023 at 2:09 pm
jetnis.avdijaj
SubscriberHello,
I am modeling a complex industrial furnace in a steady state regime.
When I open the case, this appears:----------------------------------------------------------------------------
bandwidth reduction using Reverse Cuthill-McKee: 413193/25410 = 16.261Info: The mesh contains elements that are invalid or of poor quality.   A different numerical scheme will be applied to these elements,   which may affect the quality of the solution. It is recommended   that you consider removing the invalid and poor quality elements   in the mesh.   For more information on the invalid and poor quality elements,   please use the following TUI commands:   /mesh/check   /mesh/repair-improve/report-poor-elements.   materials,   interface,   domains,mixture   zones,...... all zones loaded,
Done.
When I apply all the BC's and I click on initialization, this appears:==============================================================================
Node 14: Process 13064: Received signal SIGSEGV.
999999: mpt_accept: error: accept failed: No error
= Â RANK 39 PID 11916 RUNNING AT DESKTOP-K29GIF8
August 18, 2023 at 2:16 pm
Forum ModeratorIf the solver is flagging corrupt cells you may find fixing the mesh will remove the issue. The error is likely linked to the solver being unable to process data in some cells.Â
- The topic ‘Node 6: Process 8068: Received signal SIGSEGV’ is closed to new replies.
