LS Dyna
LS Dyna
Nodal rigid body problem
    • tut06916
      In LS-DYNA, when defining multiple *CONSTRAINED_GENERALIZED_WELD_SPOT constraints, if the node sets of two constraints contain the same node, the following error is reported:
      Does LS-DYNA have another type of constraint or tie that allows two constraints to have node sets sharing the same node?
    • ErKo
      Perhaps use spotweld beams (*MAT_SPOTWELD_TITLE and elform=9 on beam section)
      Sure other users might have other ideas - wait for feedback.
      All the best
      Erko
      • tut06916
        Should I use *ELEMENT_BEAM or *ELEMENT_DISCRETE to create elements btw 2 nodes? And what section should I use?
