April 15, 2019 at 6:29 pm
clicker22
SubscriberGood morning,
I would like to constrain a single node with a displacement constraint. In ANSYS WB is there a way to select something other than geometries to place a constraint on?
For example, below I placed a displacement constraint on the elevated portion of the geometry. I would like to delete the raised portion and just select a node to place the same constraint on.Â
April 16, 2019 at 1:28 am
Sandeep Medikonda
Ansys EmployeeYou can select a node from the Graphics toolbar.
Refer to this help section.
Additionally, you can also use named selections to convert geometry entities into nodal selections.
- The topic ‘Nodal Constraint’ is closed to new replies.
1638
1386
1242
