no surface tension option at polyflow
    • mn2n25
      hello i am running a 2d extrusion simulation with the following boundry conditions at fluent polyflow
      inlet>> inflow >> normal velocity which is the value of the velocity of the entering fluid
      outlet >> out flow>> normal velocity which is the value of the velocity of the fluid that exist the domain
      left and write boundarries are free surface luike a hollow core cylinder
      the problem is that  i cand see surface tension option when consider a boundry as a free surface you can see my options on the following screenshot. i sont see any surface tension to activate .
    • Prashanth
      Hello, which release is this? Surface tension in Fluent Polyflow is a beta feature, it will be a release feature from 2026R1
