January 2, 2024 at 2:20 pm
Lukas Paul
SubscriberWhen trying to solve a Mechanical stress simulation i get the error:
(DP 0) The solution may not start if the correct GPU unit is not installed on the computer on which you are running the solution. Please check the requirements for the GPU unit carefully.
(Translated from german)
I run a relativly new setup with an 12th gen i9 with 64GB of DDR5 Ram. Due to my limited budget i still run an old GTX 1060 6GB GPU, a newer card is no option at the moment.
Is there a way to NOT use the GPU and simply solve using only the CPU as for now the speed is not as important and the GPU would probably not contribute in any meaningful way. The way it is now it cannot solve the setup at all.Thank you in advance
January 2, 2024 at 2:28 pm
Lukas Paul
SubscriberAnsys Mechanical Enterprise Academic Student    Â
 ANSYS-LIZENZMANAGERFEHLER:
 Not enough HPC Parallel licenses 13/4.
 *** ERROR - Insufficient HPC licenses available.
whybad=Â Â Â Â Â Â -1074
+--------------------- M A P D LÂ Â S T A T I S T I C S ------------------------+
Release: 2023 R2Â Â Â Â Â Â Â Â Â Â Â Build: 23.2Â Â Â Â Â Â Update: UP20230531Â Â Platform: WINDOWS x64
Date Run: 01/01/2024Â Â Time: 23:13Â Â Â Â Process ID: 24560
Operating System: Windows 11Â (Build: 22621)
Processor Model: 12th Gen Intel(R) Core(TM) i9-12900KF
Compiler: Intel(R) Fortran Compiler Version 19.0.5Â (Build: 20190815)
         Intel(R) C/C++ Compiler Version 19.0.5 (Build: 20190815)
         Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191125
         BLAS Library supplied by Intel(R) MKL
Number of machines requested           :   1
Total number of cores available        :  24
Number of physical cores available     :  16
Number of processes requested          :  12
Number of threads per process requested :Â Â Â 1
Total number of cores requested        :  12 (Distributed Memory Parallel)             Â
MPI Type: INTELMPI
MPI Version: Intel(R) MPI Library 2021.8 for Windows* OS
Number of GPUs requested               :   1
GPU Acceleration: NVIDIA Library Requested but not Enabled
GPU Device with ID =Â 0 is:
GPU Driver Version: 11.10
CUDA Version: 12.0 -
January 4, 2024 at 7:52 am
kfi
SubscriberHi,
Assuming you haven't found a solution. The GPU is turned on/off in the solve process settingsc-structural/
Also note that 1 hpu license is required - there is also an error on insuffucuent number of hpu licenses in the out-file
January 4, 2024 at 6:33 pm
Lukas Paul
SubscriberToday i had some help from a supervisor and it turns out the GPU did count as a hpu even when turend off and the amount of cores was not automatically adjusted to the number available for my license.
if anyone encounters similar problems it canbe manualy set under Ansys Mechanical enterprise ->right click on solutions ->my PC-> extended Properties and then needs to be set .
(all translated from german so garantee on the naming)
thanks for the reply
- The topic ‘No Solving possible due to GPU Issues’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3977
1461
1272
1124
1015
