No Section/Material related function found in binlib.lib
    • Qiuyuhao
      I am currently using ANSYS 19.2 for secondary development. Although ANSYS has good support for secondary development, I still encountered some problems.
      I found that there are no functions related to Section and Material in the Binlib library .That's weird, because they are defined in RstRd.F.
      I will be very grateful if anyone can give me some suggestions.
      (I used dumpbin commond to figure out the composer of binlib.lib, and found that it dose't have those funcitons)
    • Qiuyuhao
      Can anyone help men
    • ashish.khemka
      Hi @Qiuyuhao, ,nnYou already have post open on the same topic:nn
      Hello, I am currently using ANSYS 19.2 for secondary development. Although ANSYS has good support for secondary development, I still encountered some problems. I found that there are no functions related to Section and Material in the Binlib library .That's weird, because they are defined in RstRd.F. I will be very grateful if anyone can give me some suggestions.(I used dumpbin commond to figure out the composer of binlib.lib, and found that it dose't have those funcitons)https://us.v-cdn.net/6032193/uploads/UVSJ6O8PTA8E/20210125164156.pnghttps://us.v-cdn.net/6032193/uploads/RLPXAYV47EN1/20210125164220.png/forum/discussion/23908/no-section-material-related-function-found-in-binlib-lib
      nI will mark this one as resolved.nnRegards,nAshish Khemkann
  • The topic ‘No Section/Material related function found in binlib.lib’ is closed to new replies.
