October 28, 2021 at 10:27 pm
dazhigulov
SubscriberHi!
I am having troubles with simulating waveguide couplers. I am attaching my simulation screenshot for your convenience. Basically, when I connect two couplers together (one with coupling ratio of 0.95 and the other with 0.05) I don't have any output at the upper port (port 3) of the latter device when reading it with ONA. If I use a single coupler I can read both outputs with ONA. I am sure this issue has something to do with the fact that the second waveguide coupler has light at both of its inputs (and one of them is phase shifted by pi/2). I hope you can clarify the origin of this behavior for me. Thank you!
Dias
October 30, 2021 at 12:01 amOctober 30, 2021 at 1:03 amdazhigulov
SubscriberYes, thanks! I actually realized that there is no signal at that port right after posting this.
Viewing 2 reply threads- The topic ‘No results in ONA when reading one of the outputs of waveguide coupler’ is closed to new replies.
5939
1307
