March 27, 2023 at 10:10 am
joe jackson
SubscriberI seem to be having issue with the no merge options. If I use the face of a shape as a sketch plane, the no merge option doesnt work and my new shape automatically gets merged to the original shape?  Any insight is helpful. I need to be able to build multiple objects to be pulled apart for separate 3D printing needs.
March 27, 2023 at 12:31 pm
Atharv Joshi
Forum ModeratorHi joe jackson
Let me check and get back to you,
Thanks and Regards
March 27, 2023 at 1:01 pm
Atharv Joshi
Forum ModeratorHi joe jackson ,
If you are creating a sketch and then pull with "no merge" active it will still create a merged solid. You have to create a surface by using fill tool while in sketch mode and then use pull with "No merge".
I have prepared a small video for you. Let me know if this solves your problem.
Thanks and Regards
​ 🛈​ This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions​-
March 27, 2023 at 1:10 pm
joe jackson
SubscriberAtharv Joshi Awesome. Thanks!     I like your layout colors and the pop up with your cursor. Much easier on the eyes.
March 27, 2023 at 1:23 pm
- The topic ‘No merge options’ is closed to new replies.
