March 19, 2020 at 10:35 am
March 19, 2020 at 11:52 am
DrAmine
Ansys EmployeeCfx does only allow for pseudo 2d cases: one cell thickness in the depth. -
March 19, 2020 at 12:02 pm
jmperido1
SubscriberThanks
March 19, 2020 at 12:26 pm
DrAmine
Ansys EmployeeWelcome
September 10, 2020 at 10:32 am
Fernando
SubscriberHello,nnI take this messages as base, because I have the same problem. But I have a 3D mesh. In fact, the mesh is the one in the Workshop 1-Mixing Tee (ANSYS CFX Getting Started).nI thought it could be because the versions (I'm using 2019r3 and the model is made in 2019r2), but I have the same problem if I import the step and I mesh the geometry in 2019r3.nnDo you have an idea about which could be the problem?.Thank you very much in advance,nFernando
n
nn
September 10, 2020 at 1:19 pm
Forum ModeratorHave a look at the cell quality. In your case I think the mesh is struggling to fill the tet region, and may be corrupted/inside out. n -
September 14, 2020 at 10:05 am
Fernando
SubscriberHello Rob,nnThank you for the answer. I have changed the mesh and it seems not to be the problem. The mesh input in the tutorial, not the shown in the image, does not also work.nAfter a little research I have found the problem is the file is in a long path (long string, I mean). Workbench and the mesh worked fine with it, but not CFX. I didn't know that.nFor information, the project (*.wbpj) was in a 120 characters long path:n C:\0_FAZ\ANSYS\CFX_GS_2019R2_EN_Student\Student\M01 -Â Overview of CFD Process\CFX_GetStart1_19.0_WS01_Inputs_Mixing_TeennI have saved the project in the following folder, and it works properly:n C:\0_FAZ\ANSYS_work\WS01_Inputs_Mixing_TeennRegards!nFernandon -
September 14, 2020 at 12:54 pm
Forum ModeratorGlad to hear it's working. As a comment, avoid spaces in folder structures too, they're mostly OK now but some functions may struggle with them. n -
September 14, 2020 at 2:20 pm
Fernando
SubscriberThanks!n
Viewing 8 reply threads
- The topic ‘No domains have been defined’ is closed to new replies.
