July 19, 2021 at 8:43 am
July 19, 2021 at 11:35 am
Naresh Patre
Ansys EmployeeHello Prathap Hoodi Muniraj Can you first check if the license mode is set as Subscription? You can check this by launching Discovery Licensing Mode Manager from Windows Start menu. If the license option is set to floating, please set it to Subscription and try again. Secondly, one of the error messages that you shared state that license entitlement have not been refreshed. Please refresh the subscription license using the refresh command mentioned in below post. Discovery Subscription license - Command line options - Knowledge Base - Ansys Discovery Forum Please let me know if the issue persists. -
July 19, 2021 at 1:25 pm
July 20, 2021 at 11:31 am
Naresh Patre
Ansys EmployeeHello Prathap Hoodi Muniraj Looking at the errors, it appears that the connection to the server is getting blocked. Can you ask the customer to make the changes to the firewall as mentioned in section 5A of below mentioned document? https://discoveryforum.ansys.com/t/q5gwjy/discovery-license-activation-troubleshooting Once done, please try executing the refresh command and see if it succeeds. If it still fails, please send all the files as mentioned in section 6 of the same troubleshooting document. -
July 22, 2021 at 6:24 am
prathap
SubscriberHello Naresh Patre
We are happy to hear from the customer that the product is working fine. The issue with the Firewall was resolved.
Thank you once again for your support.
Viewing 4 reply threads
- The topic ‘No Discovery Licenses found. Operating in Read only mode.’ is closed to new replies.
1306
