No cut cell method in CFD Preppost (ANSYS 2024 R2) ?
    • garcia
      Hello everybody,
      I'm trying to learn how to mesh bodies with the "cut cell" method but I do not find where to activate this method in CFD Preppost... Is this a license problem ? I checked several times, my model is well prepared (multiple parts, topology shared...)
      Thanks in advance...
    • Federico
      Hello Pierre,
      what product are you using for your meshing?
      • garcia
        Thanks for your answer.
        Im using The fluid flow (fluent) on workbench with the ansys meshing method so basically its cfdpreppost that deals with the mesing...
      • garcia
        Hi again,
        It seems that the cut cell method is for "cfd enterprise" licence user only, but I checked it and I already have it.
      Cutcell was under Assembly meshing in older versions of Ansys Meshing but was removed in about R19. The poly-hexcore option in Fluent Meshing is an improved replacement, or for multiphase flows pure poly can be better.
