No contact penetration of CONTA178 elements – Bearing simulation
    • tim.hertinger
      Hello all,
      I would like to calculate the contact penetration of a tapered roller bearing by using CONTA178 elements between the raceways. So that, I´ve created a model with 30 contact elements including a pre-defined gap along the surface of the raceway and applied a constant pressure around the surface of the outer ring to simulate the pre-load of the bearing. The gap should simulate the profile of the logarithmic raceways.
      However, while solving the model I didn´t get any connection between the outer ring and rollers. The CONTA178 elements are still open and there isn´t any contact penetration. I´m not sure whats the reason for that, I tired to vary the boundary conditions a bit, but that doesn´t helped.
      I would be very happy if someone here can help me.
      Thank you.
      import matplotlib.pyplot as plt
      import numpy as np
      import math as m
      import itertools
      import pandas
      from ansys.mapdl.core import launch_mapdl
      mapdl = launch_mapdl()
      mapdl.prep7()
      mapdl.units("SI")
      mapdl.et(1, "SOLID185")
      mapdl.mp("EX", 1, 210e9)
      mapdl.mp("DENS", 1, 7800)
      mapdl.mp("NUXY", 1, 0.3)
      mapdl.type(1)
      mapdl.keyopt(1, 2, 3)
      mapdl.et(2, "CONTA178")
      mapdl.mp("EX", 2, 210e9)    # Elastic moduli in Pa (kg/(m*s**2))
      mapdl.mp("DENS", 2, 7800)   # Density in kg/m3
      mapdl.mp("NUXY", 2, 0.3)    # Poisson's Ratio
      mapdl.type(2)
      mapdl.keyopt(2, 3, 1)
      mapdl.keyopt(2, 4, 1)
      mapdl.keyopt(2, 5, 0)
      mapdl.keyopt(2, 10, 0)
      mapdl.keyopt(2, 12, 1)
      # Slicing
      anzahl_scheiben = 30
      anzahl_scheiben_board = 20
      # Geometry
      anzahl_rollen = 16
      # Inner ring
      di = 0.065      #Innen-Durchmesser Lagersitz
      bi = 0.041      #Breite Lagersitz
      α  = 7.6        #Druckwinkel
      β  = 9.6        #Hilfswinkel
      o = 0.009238
      p = 0.008282
      q = 0.003962
      r = 0.000671
      s = 0.02539
      t = 0.003391
      v = 0.005083
      w = 0.00079 #0.00086
      b = 0.006658
      # Inner ring - Keypoints
      mapdl.k(1, 0, di/2, 0)
      mapdl.k(2, 0, di/2+o, 0)
      mapdl.k(3, 0, di/2+o, p)
      mapdl.k(4, 0, di/2+o-q, p+r)
      mapdl.k(5, 0, di/2+o-q+t, p+r+s)
      mapdl.k(6, 0, di/2+o-q+t+v, p+r+s-w)
      mapdl.k(7, 0, di/2+o-q+t+v, p+r+s+b)
      mapdl.k(8, 0, di/2, bi)
      mapdl.k(13, 0, 0, 0)
      mapdl.k(14, 0, 0, -0.005)
      mapdl.k(15, 0, 0, 0.005)
      # Inner ring - Lines
      li_1 = mapdl.l(1, 2)
      mapdl.l(2, 3)
      mapdl.l(3, 4)
      l1_i = mapdl.l(4, 5)
      l1_b = mapdl.l(5, 6)
      mapdl.l(6, 7)
      mapdl.l(7, 8)
      li_8 = mapdl.l(8, 1)
      # Inner ring - Surface
      a1 = mapdl.a(1, 2, 3, 4, 5, 6, 7, 8)
      mapdl.lesize(nl1=li_1, ndiv=3) #Boundary Conditions, Definition der Anzahl von Elementen
      mapdl.lesize(nl1=li_8, ndiv=10)
      # Outer ring
      ba = 0.032      #Breite Lagersitz
      c = 0.00732
      e = 0.010942
      f1 = 0.032
      g = 0.00439
      da = di+2*(o+c+e)      #Außen-Durchmesser
      # Outer ring - Keypoints
      mapdl.k(9, 0, di/2+o+c, 0)
      mapdl.k(10, 0, da/2, 0)
      mapdl.k(11, 0, da/2, f1)
      mapdl.k(12, 0, da/2-g, f1)
      mapdl.k(16, 0, da/2-0.00439, f1-0.000102) # Kontaktpunkte Kegelrolle, evtl. über zyl. KOS bestimmen, statt über Winkelfunktion auszurechnen!
      mapdl.k(17, 0, da/2-0.00955, f1-0.025245) # Kontaktpunkte Kegelrolle, evtl. über zyl. KOS bestimmen, statt über Winkelfunktion auszurechnen!
      # Outer ring - Lines
      mapdl.l(9, 10)
      l_a_f = mapdl.l(10, 11)
      mapdl.l(11, 12)
      mapdl.l(12, 16)
      l1_a = mapdl.l(16, 17)
      mapdl.l(17, 9)
      mapdl.lesize(nl1=l1_a, ndiv=anzahl_scheiben-1) #Scheibenmodell Außenring-Lauffläche
      mapdl.lesize(nl1=l1_i, ndiv=anzahl_scheiben-1) #Scheibenmodell Innenring-Lauffläche
      mapdl.lesize(nl1=l1_b, ndiv=anzahl_scheiben_board-1) #Scheibenmodell Innenring-Bordkontakt
      mapdl.lesize(nl1=l_a_f, ndiv=10)
      # Outer ring - Surface
      a2 = mapdl.a(9, 10, 11, 12, 16, 17)
      # Extrudieren - Innenring & Außenring
      mapdl.vrotat(a1, pax1=14, pax2=15, arc=360, nseg=anzahl_rollen) #Hier bei nseg noch Anzahl Rollen einfügen
      mapdl.vrotat(a2, pax1=14, pax2=15, arc=360, nseg=anzahl_rollen)
      # Roller
      f2 = 0.044114
      a1 = 0.004275
      a2 = 0.00788
      m1 = 0.025241
      h = 0.006887
      a3 = 0.005862
      a4 = 0.006707
      a5 = 0.001135
      a6 = 0.006322
      # Roller - Keypoints
      mapdl.k(2000000, 0, f2, a2)
      mapdl.k(2100000, 0, f2+a1, a2+m1)
      mapdl.k(3000000, 0, f2+a3, h)
      mapdl.k(3100000, 0, f2+a1+a4, a2+m1-a5)
      # Roller - Lines
      l1_k = mapdl.l(2000000, 3000000)
      l2_k = mapdl.l(3000000, 3100000)
      mapdl.l(3100000, 2100000)
      l3_k = mapdl.l(2000000, 2100000)
      # Roller - Surface
      f_a3 = mapdl.a(2000000, 3000000, 3100000, 2100000)
      mapdl.lesize(nl1=l2_k, ndiv=anzahl_scheiben-1)
      # Extrude - Roller
      mapdl.vsel("NONE")
      k_rot = mapdl.vrotat(f_a3, pax1=2000000, pax2=2100000, arc=360, nseg=2)
      mapdl.csys(1)
      mapdl.vgen(itime=anzahl_rollen, nv1="ALL", dy=360/anzahl_rollen, imove=0)
      mapdl.vsel("ALL")
      # Meshing
      mapdl.csys(0)
      mapdl.vsweep("ALL")
      # Creation of contact elements
      # Selection of lines
      mapdl.lsel("S", "NDIV", vmin=anzahl_scheiben-1)
      #print(mapdl.geometry.lnum)
      mapdl.lplot(vtk=True, show_line_numbering=True, background="white", color_lines="black")
      polar_rollen = 360/anzahl_rollen
      radius_ir = di/2+o-q+0.001
      radius_ri = di/2+o-q+0.002
      radius_ra = f2+a3+0.001
      radius_ar = f2+a6+0.0025
      x_ir = []
      x_ri = []
      x_ra = []
      x_ar = []
      y_ir = []
      y_ri = []
      y_ra = []
      y_ar = []
      for i in np.arange(0, 360+polar_rollen, polar_rollen):
          x_ir.append(radius_ir*np.sin(np.radians(i)))
          x_ri.append(radius_ri*np.sin(np.radians(i)))
          x_ra.append(radius_ra*np.sin(np.radians(i)))
          x_ar.append(radius_ar*np.sin(np.radians(i)))
          y_ir.append(radius_ir*np.cos(np.radians(i)))
          y_ri.append(radius_ri*np.cos(np.radians(i)))
          y_ra.append(radius_ra*np.cos(np.radians(i)))
          y_ar.append(radius_ar*np.cos(np.radians(i)))
      ### Selection of Nodes on selected Lines between future contact (Not shown in this post) ###
      # Contact definition
      mapdl.vsel("ALL")
      # Inner ring - Roller
      profil_ir = [0.000012544,    0.000010816,    0.000009216,    0.000007744,    0.0000064,    0.000005184,    0.000004096,    0.000003136,    0.000002304,    0.0000016,    0.000001024,    0.000000576,    2.56E-07,    6.4E-08,    0,    6.4E-08,    2.56E-07,    5.76E-07,    0.000001024,    0.0000016,    2.304E-06,    3.136E-06,    0.000004096,    0.000005184,    0.0000064,    0.000007744,    9.216E-06,    0.000010816,    0.000012544,    0.0000144]
      ri_nnum_flip = np.roll(ri_nnum, anzahl_scheiben-1, axis=1)
      mapdl.type(2)
      for a in range(0, anzahl_rollen, 1):
          for i in range(2, anzahl_scheiben+2, 1):
              mapdl.r(i, r1=-210000, r2=profil_ir[i-2])
              mapdl.real(i)
              mapdl.e(ir_nnum[a][i-2], ri_nnum_flip[a][i-2])
      # Outer ring - Roller
      profil_ar = [0.000012544,    0.000010816,    0.000009216,    0.000007744,    0.0000064,    0.000005184,    0.000004096,    0.000003136,    0.000002304,    0.0000016,    0.000001024,    0.000000576,    2.56E-07,    6.4E-08,    0,    6.4E-08,    2.56E-07,    5.76E-07,    0.000001024,    0.0000016,    2.304E-06,    3.136E-06,    0.000004096,    0.000005184,    0.0000064,    0.000007744,    9.216E-06,    0.000010816,    0.000012544,    0.0000144]
      ar_nnum_flip = np.flip(ar_nnum, axis=1)
      ra_nnum_roll = np.roll(ra_nnum, anzahl_scheiben-1, axis=1)
      mapdl.type(2)
              mapdl.r(i, r1=-210000, r2=profil_ar[i-2])
              mapdl.real(i)
              mapdl.e(ar_nnum_flip[a][i-2], ra_nnum_roll[a][i-2])
      mapdl.eplot(vtk=True, show_edges=True, show_axes=True, line_width=1, show_node_numbering=False)
      # Boundary conditions
      # Innenring
      # radial
      mapdl.allsel()
      mapdl.csys(1)
      mapdl.nsel("S", "LOC", "X", vmin=di/2-0.001, vmax=di/2+0.001)
      mapdl.d("ALL", "UX")
      mapdl.d("ALL", "UY")
      # axial
      mapdl.allsel()
      mapdl.csys(0)
      mapdl.asel("S", "LOC", "Z", vmin=p+r+s+b-0.001, vmax=p+r+s+b+0.001)
      mapdl.nsla("S", 1)
      mapdl.d("ALL", "UZ")
      # Outer ring
      # axial
      mapdl.allsel()
      mapdl.csys(0)
      mapdl.asel("S", "LOC", "Z", vmin=0, vmax=0.001)
      mapdl.csys(1)
      mapdl.asel("R", "LOC", "X", vmin=di/2+o+c, vmax=di/2+o+c+e)
      mapdl.nsla("S", 1)
      mapdl.csys(0)
      # Roller
      mapdl.allsel()
      mapdl.csys(0)
      mapdl.vsel("S", "LOC", "Z", vmin=p+r+s/2-0.0015, vmax=p+r+s/2+0.0015)
      mapdl.csys(1)
      mapdl.vsel("S", "LOC", "X", vmin=f2, vmax=f2+0.005)
      mapdl.nslv("S", 1)
      mapdl.csys(1)
      # Forces
      mapdl.allsel()
      mapdl.csys(1)
      mapdl.asel("S", "LOC", "X", vmin=di/2+o+c+e-0.001, vmax=di/2+o+c+e+0.001)
      mapdl.sfa("ALL", 1, "PRES", value=2000)
      # Solve
      mapdl.run("/SOL")
      mapdl.antype(0)
      mapdl.outres("ALL", "ALL")
      mapdl.run("/STATUS,SOLU")
      sol_output = mapdl.solve()
      mapdl.finish()
      print(sol_output)
      # Plot results
      result = mapdl.result
      result.plot_principal_nodal_stress(
          0,
          "SEQV",
          lighting=False,
          background="w",
          show_edges=True,
          text_color="k",
          add_text=False,)
      nnum, stress = result.principal_nodal_stress(0)
      von_mises = stress[:, -1]
      max_stress = np.nanmax(von_mises)
      # Contact Penetration
      mapdl.allsel()
      mapdl.lsel("S", "LINE", vmin=4)
      mapdl.nsll("S", 1)
      mapdl.esln("S", 0)
      mapdl.esel("R", "ENAM", "", 178)
      mapdl.eplot(vtk=True)
      contact_penetration_r = mapdl.post_processing.element_values(item='nmisc', comp=3)
      print(contact_penetration_r)
      mapdl.post1()
      mapdl.set("last")
      mapdl.allsel()
      mapdl.post_processing.plot_nodal_principal_stress("1", smooth_shading=False)
      mapdl.exit()
      v.Mises Stress Bearing
    • Ashish Khemka
      You can search for the following keywords: 'tapered roller bearing ansys' and you can get a video on tapered roller bearing in  Ansys Mechanical.
      May be a ds.dat file on this analysis might help.
      Ashish Khemka
    • Mike Rife
      Hi Tim
      The default of Contact 178 gap is to use the node locations plus the real constant defined GAP as the total contact gap.  This is not appropriate for the way this model is set up (otherwise that is a huge contact gap to close!).  Change the element type 2 keyoption to use just the real constant GAP as the contact gap:
      keyopt,2,4,1
      Also the ET command was issued twice to define element type 2 (guessing copy/pasted the code block).  The command should only be issued once per element type otherwise could easily run into issues.  So take out the second instance.
      Next the "Contact Penetration" commands are post processing commands that should be moved to after the mapdl.set("last") command.
      Lastly the PyMAPDL Reader, used via the result=mapdl.result is being deprecated.  In the future either post process with native PyMAPDL commands or use PyDPF.
      Mike
    • Mike Rife
      Should have added that since this is a contact analysis then it should be run as non-linear i.e. use the nlgeom command to turn on large deformations.
    • tim.hertinger
      I am a bit confused that there are still no stresses on roller and inner ring raceway. I have updated my model as described above and can obtain the contact penetration now. But the stresses are looking the same. Any reasons for that?
    • Mike Rife
      Because the stresses in the bearings are very small compared to the whole model.  Unselect the housing volumes, then reselect the elements/nodes attached to the remaining volumes, and replot the stress….what happens?
      In the image above you can kindof see the bearing stresses as one pixel...or a line of single pixels for the top bearing.  Removing the housing volumes/elements will help see these as well.
Viewing 5 reply threads
  • The topic ‘No contact penetration of CONTA178 elements – Bearing simulation’ is closed to new replies.
