April 11, 2024 at 8:52 pm
April 12, 2024 at 6:58 am
Devendra Badgujar
Forum ModeratorHello Wen Liu,Â
Please make sure you are searching in the correct location as shown below:Â
C:\Program Files\ANSYS Inc\v241\scdm\SpaceClaim.Api.V23
These are available directly with installation.Â
Devendra
April 12, 2024 at 3:01 pm
wen_liu
SubscriberThanks Devendra. I found it; but am I correct that none of the library files in V23 provide python syntax?
April 16, 2024 at 8:58 am
Devendra Badgujar
Forum ModeratorHello Wen,Â
Thanks for your update. Can you please explain what exactly you were looking for so that I can help you find it?Â
Regards,Â
DevendraÂ
April 16, 2024 at 12:15 pm
wen_liu
SubscriberHi Devendra, I am trying to write a script in SpaceClaim to create some periodic structure; though the programming language I am most familiar with is Python, so I am trying find a documentation which can show me python syntax.Â
April 16, 2024 at 12:36 pm
Devendra Badgujar
Ansys SpaceClaim offers scripting capabilities that you can utilize with Python. You can create a new script by selecting File > New > Script, which opens up the Script Editor. The tutorial Discovery SpaceClaim: Model Prep for CAE & MFG - Scripting mentions that with some knowledge of Python and familiarity with the SpaceClaim API, you can automate tasks such as importing and repairing files or creating basic geometry. Additionally, there's a function to insert code snippets from a predefined library of operations and commands, which can be accessed from the Insert Code Snippet button in the Script Editor toolbar
Furthermore, the "Scripting" documentation for SpaceClaim provides information on the Class Library for a detailed description of the API, which can be found in the installation directory of SpaceClaim. This resource is particularly useful if you're looking to work with SpaceClaim programmatically using Python.
For SpaceClaim: C:\Program Files\SpaceClaim
\SpaceClaim.Api. I hope this helps. Thank you!Â
DevendraÂ
- The topic ‘No API_Class_Library.chm file in SpaceClaim.Api.V23 sub-folder’ is closed to new replies.
5824
