February 2, 2021 at 7:16 pm
Asif_Ahmed_05
SubscriberFebruary 3, 2021 at 1:48 pmKarthik Remella
AdministratorAre you trying to read a new mesh file into an existing case file? If so, I'd suggest that you start setting up the case from scratch. Read the mesh file as the starting point and start setting-up your case from the beginning and see if you get the same error. Please let us know your findings.nKarthiknViewing 1 reply thread- The topic ‘No Active Application error ,Cortex Recieved a Fatal Signal’ is closed to new replies.
6745
1324
1087
