Electronics
Electronics
Nexxim/SPICE/ Twin Builder
    • gary
      I have a netlist of a circuit that I can run under Nexxim.  It requires accurate transistor models.  However, I want to include it as part of an interface to a Maxwell Model (transient).  It seems in order to do this, I must work in Twin Builder.  When I make a subcircuit in Twin Builder, it runs Berkeley SPICE (instead of Nexxim).  Unfortunately, Berkeley SPICE does not support the most important transistor model parameters.  Hence, the circuit (netlist) does not run properly in Berkeley SPICE.  Using standard library components (transistors, etc...) the result is the same.  Is there anyway around this?
      Is there a way to run Nexxim with Twin Builder subcircuits?  I am at a dead end.
      Thanks
    • Dan Dv
      Hello Gary,
      Unfortunately Nexxim and Twin Builder are not compatible with each other. So no we can't have a Nexxim circuit block running inside of Twin Biulder or vice versa.
    • Sebastiano Santarpia
      I have the same problem. I have an Igbt model in simplorer, and I want make DC sweep, but the tool is only available in circuit tool, not simplorer? any hint?
      • Dan Dv
        Unfortunately we cannot run Simplorer model in the Circuit tool. You would have to obtain an HSPICE or PSPSICE syntax model of the IGBT in order to run the DC sweep in Circuit.
  • The topic ‘Nexxim/SPICE/ Twin Builder’ is closed to new replies.
