February 18, 2023 at 6:05 am
Christof Schramm
SubscriberWithin the lasr two weeks I received an email from you that a patch or an upgrade for spaceclaim could be downloaded. Unfortunately this email is lost and I please you to send this message again.
Best regards,
Christof Schramm
February 20, 2023 at 1:15 am
Atharv Joshi
Forum ModeratorHi Christof Schramm ,
You can refer to this KM for downloading the patch January 2023 Subscription Licensing Issue - Knowledge Base - Ansys Discovery Forum
Let me know if you need further assistance.
Thanks and Regards
February 21, 2023 at 3:21 am
Christof Schramm
SubscriberHello Atharv,
thank you for the reply. The installation was successful. I have since months the following information from the Spaceclaim software shown after every system sart:
Add-in 'Excel Dimension Editor' verwendet API V12, die im nächsten Release ausläuft. Dieses Add-in ist in der nächsten Version von SpaceClaim nicht mehr verfügbar, es ist ein Upgrade auf API V14 oder höher erforderlich.
ÂTranslation:Â Add-in 'Excel Dimension Editor' uses API V12, which will be phased out in the next release. This add-in will no longer be available in the next version of SpaceClaim, an upgrade to API V14 or higher is required.
What can I do?
Best regards,
Christof Schramm
February 23, 2023 at 8:18 am
Atharv Joshi
Forum ModeratorHello Christof SchrammÂ
This is just an informational message that you are seeing, and the add-in should work normally.
Are you using any old add-in in SpaceClaim?
Regards
February 23, 2023 at 8:45 am
February 28, 2023 at 3:07 am
Atharv Joshi
Forum ModeratorHello Christof Schramm ,
The Excel Dimension Editor which you are using has been updated with 2023R1. The pop-up message will appear when you load up if the add-in is activated.
Please ignore as this doesn't cause any functionality issue with the add-in.
If you install SpaceClaim 2023R1, you will see the updated add-in as seen in the attached image.
February 28, 2023 at 4:31 am
Christof Schramm
SubscriberHello, Atharv,
when will SC 2023R1 be available and where?
Best regards
Christof Schramm
March 21, 2023 at 7:00 am
Atharv Joshi
It is already released, and you can download it from Discovery Downloads - Knowledge Base - Ansys Discovery Forum.
Thanks and Regards
- The topic ‘New Patch/Upgrade for SPaceclaim’ is closed to new replies.
6019
