April 30, 2024 at 4:51 am
Nawaf Rasheed
SubscriberHey
I've multiphase model, the fluids in the models are liquid water and vapor water. But, I'm trying to define the properties of those under vacuum (low pressure). Which means Low Latent Heat of Vaporization (hfg) from water table in thermodynamics. But the only available properties in fluent is shown belowÂ
Any advice?
Or fluent ANSYS has those table databases. So, it's been applied automatically
April 30, 2024 at 8:05 am
SRP
Ansys EmployeeHi,
When defining properties for liquid water and vapor water under vacuum conditions in Ansys Fluent, you may need to manually input the properties if they are not available in the Fluent database.you can create a new materials database, copy materials to database.
You can check fluent user's guide for more details: 8.1. Defining Materials (ansys.com)
Hope this helps you.
- The topic ‘New Material properties, Latent Heat of Vaporization’ is closed to new replies.
5834
