TAGGED: import, importing-data, material, material-data
July 18, 2024 at 7:28 am
July 19, 2024 at 6:41 pm
Amrita Pati
Ansys EmployeeHi Mustafa,
I tested something similar and I was able to import the data without any issue. The wavelength is not being populated as well. Are there any spaced in front of the data? The first column should be wavelength, the second should be the real part of the index, and the 3rd should be the imaginary. I am wondering there are spaces before the first column? Here's what the data I use look like:
I will recommend you to also make sure that the unit of the wavelength is correct when you import the data.
Amrita -
July 22, 2024 at 10:04 am
Mustafa Berkay Sokmen
Subscriberyes in the one I uploaded there are spaces but I have already tried without the spaces. Also tried changing the wavelength unit, using commas instead of dots, using commas instead of spaces. Tried as ".yaml" file. Here how the file I generaly tried looks like:
275.44 2.44991257 0.33115524
277.03 2.44801587 0.3117007
278.62 2.4449101 0.2928575
280.22 2.44072204 0.27472102
281.81 2.43558114 0.25736217
283.4 2.42961505 0.24082882
284.99 2.42294624 0.22514871
286.58 2.41568999 0.21033313
288.18 2.40795253 0.19637917
- The topic ‘New Material Importing, Only Takes Integer Part’ is closed to new replies.
