July 10, 2024 at 4:09 pm
jie li
SubscriberWhen running the scan, the following problems occur:Nested sweep must have the same solver.How to solve them,please
July 11, 2024 at 5:43 am
Amrita Pati
Ansys EmployeeHi Jie,Â
Could you please send a screenshot of the sweep window (where you setup the parameters and the results) of both inner and outer sweeps? Also, which version of Lumerical are you using?Â
Amrita -
July 11, 2024 at 4:20 pm
jie li
SubscriberThe parameter Settings are shown in the first figure, which is case "Diffuse Scattering Film for Automotive Display" from the official website for calculating BSDF. In addition, I found that the case does not run directly because script file "bsdf_export2Speos_functions" can not run . and my software version is 2024R1
- The topic ‘Nested sweep must have the same solver.’ is closed to new replies.
1890
1419
1304
