February 12, 2021 at 7:41 am
andrewtck96
SubscriberI have been trying to simulate a compression test for large strain of a Polylactic Acid specimen using LS-DYNA. I defined the material as hyperelastic, using the curve fitting for the Mooney-Rivlin 5 parameter model, and including isotropic elasticity data to calculate the young's modulus.
In the set up in Ansys Mechanical, the top and bottom platens are set as structural steel, while the specimen is set as PLA.
However, the simulation does not run. All the elements and nodes are deleted at time = 0s because of negative volume. Based on what I have read in the forum, this is due to the meshing of the model, but I have not been able to tweak the mesh settings such that the simulation can run.
I've included screenshots of the material properties, the mesh and analysis settings, as well as the output of negative volumes that is shown in the solver window.
Can anyone point me in the right direction to set up the simulation in Ansys Mechanical? I would be really grateful.
February 16, 2021 at 2:19 pmAshish Khemka
Forum ModeratorHi Array,nnNegative Volume error message appears if materials undergo extremely large deformations such as soft foams an element may become so distorted that the volume of the element is calculated as negative. You can stop this error by reducing the time step size by changing the Time Step Safety Factor from default value (0.9) to lesser values (0.5 or 0.1).nnRegards,nAshish KhemkanFebruary 16, 2021 at 2:25 pmandrewtck96
SubscriberThanks for the advice, Ashish!nI have already tried changing the hourglass control to 4 or 5, based on the information from this LS-DYNA page on negative volumes. The simulation was able to run, although the results were not very accurate.nI will try reducing the time step safety factor and post an update here once I have done so.Regards,nAndrewnFebruary 17, 2021 at 2:42 amandrewtck96
SubscriberI have succeeded in running the simulation by reducing the time step safety factor to 0.5. The result was also much more realistic that the simulations with Hourglass controls 4 and 5.nnThank you so much !nViewing 3 reply threads- The topic ‘Negative Volumes in Mesh (Ansys LS-DYNA)’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- CONVERTING STL FILE IN TO SOLID
- The meshing algorithm cannot find matching topology
- How do I fix this irregular face meshing problem?
- [ANSYS Meshing] how to activate curvature for a sizing in a script?
- ICEM O grid mesh for sloped pipe
- How to create a mapped mesh in a chain link model with stud.
- what is the best way to apply shear stress to a shell 181 element?
- Meshing Help – I keep getting errors. How would you tackle this geometry?
- Solutions for “A software execution error occurred inside the mesher.” in 2D
Top Contributors-
2537
933
787
599
591
