TAGGED: ale, lsdyna, meshing, negative-volume, negative-volume-detected
August 29, 2020 at 5:23 pm
dyy33
SubscriberHello all,
Background
I am currently working on a cylindrical LS-DYNA model that utilize the ALE method and encountering a error output related to negative volumes during advection. The model, shown in Figure 1 (a zoomed in view of the model), is consisted of multiple parts:
- Blue part is water, modeled by ALE.
- Red, green and yellow parts are the lagrangian solids. The green part is rigid while others are deformable materials.
- There is also a void part, overlapping with the lagrangian solids, not shown in Figure 1.
The cylindrical cross section exists in the XY plane and the model is 3 element thick in the Z direction.
September 3, 2020 at 7:05 pmIan Do
Ansys EmployeeHi,nNeg advection vol for ALE elms is caused by a few possible factors, FSI force, BC, prescribed motion, ... If the local force may be too high and pushes more fluid out of an ALE elm in 1 dt than there is fluid available inside that elm to start with, then we have this problem. To fix this we need to find the cause of this local spike of P or force. Then back track to find a way to smooth it out or correct it (in case of FSI force, for ex, we can reduce the coupling P in the load curve). Reducing TSSF sometimes help also.nIf your mesh has very bad aspect ratio as it is here, it may make easier to have neg-adv err in the thin dir (?). n[Q] ... lagrangian solids are more sensitive to meshing quality than ALE?n[A] Not really. All discretized methods depends on the quality of their meshes in general. LAG may be a little more, but I would not be careless with ALE neither.nnI cannot visualize clear the overlapping of the LAG-ALE meshes so I can't comment on the rest. In general, any very thin layers of ALE elms right next to a much larger layer is not recommended. The transition should be gradual. This is a complex model and a lot of details need to be analyzed. This is more of a training issue which cannot be addressed here efficiently (as we cannot trade files). Perhaps you should contact support directly as this can be quite involved. Good luck!nViewing 1 reply thread- The topic ‘Negative Volume Error during ALE Simulation in LS-DYNA’ is closed to new replies.
4893
1587
1386
1242
